The difference between getTarget() and getCurrentTarget() in TGML Scripting
  • The difference between getTarget() and getCurrentTarget() in TGML Scripting
  • CraigEl
    CraigEl
  • sesa177673
    sesa177673
‎2018-09-11 03:05 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-07 11:34 PM
Every item shown in the Objects window of the TGML editor can be considered a Node. In the figure shown below, this relatively simple TGML page has 14 nodes. Nodes are hierarchical with parent and children nodes. One important concept when scripting in TGML is finding the desired node.
Examples of this are:
  • Changing the color of a rectangle when a bound signal is offline
  • Writing a new value to a text box every time the database value updates
  • Opening a new page when the user left clicks on a component
EcoStruxure Building Operation, TAC Vista
  • StruxureWare Building Operation
  • TGML Graphics Editor
Within a script, there are two functions that will pinpoint a specific node, but have very different applications. These are:
  • getTarget()
  • getCurrentTarget()
An example function of how to use these functions is:
function click(evt){
  target = evt.getTarget();
  • getTarget() - returns where an event is coming from
  • getCurrentTarget() - returns the parent of the script
Both examples below chart the differences between the two functions using the screen capture below.
If the bind object in the figure above changes its value, here is what getTarget() and getCurrentTarget() would each return if they were a part of each script (A, B, C).
Script
getTarget()
getCurrentTarget()
A
Bind
Component
B
Bind
Rectangle
C
Bind
Bind
If the user clicks on the rectangle in the figure above, here is what getTarget() and getCurrentTarget() would each return if they were a part of each script (A, B, C).
Script
getTarget()
getCurrentTarget()
A
Rectangle
Component
B
Rectangle
Rectangle
C
N/A
N/A
Also check out the JavaScript Essentials - Programs and Statements Quick-Help video on the Exchange.
Labels (2)
  • 16906
100% helpful (11/11)
