The No Server Light is illuminated on ACX78x Controller.
  • The No Server Light is illuminated on ACX78x Controller.
  • Alan_Wood
    Alan_Wood
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 01:14 PM
Last Updated: Administrator CraigEl Administrator ‎2025-08-29 05:14 AM
Following a clean upgrade from Continuum 1.74 to 1.93, all ACX78x controllers have the No Server LED illuminated.
Andover Continuum
  • ACX780
  • ACX781
The SystemStatus system variable is set to No Database.
Additionally, the AccessServer system variable on the ACX78x controller is not correctly configured—it is not set to the ACCID of the primary access server workstation.
The No Server LED illuminates when the controller cannot establish a valid connection with the access server. This typically occurs due to misconfiguration of the AccessServer variable.
To resolve the issue:
  1. Set the SystemStatus variable to Normal.
  2. Ensure the AccessServer variable is correctly configured:
    • It must be set to 0 or to the controller’s own ACCID.
    • Do not set it to the ACCID of a workstation or any other device.
Important Note
Setting the AccessServer to any value other than 0 or the controller’s own ACCID will trigger the No Server LED, indicating a failed server connection.
Tags (2)
  • 6280
  • AlanWood25
