The File or Directory \VISTA DB\$queues\insertevents is corrupt and unreadable
  • The File or Directory \VISTA DB\$queues\insertevents is corrupt and unreadable
‎2018-09-10 11:19 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:19 AM
Error Messages:
Windows - Delayed Write Failed
Windows was unable to save all the data for the file D:\VISTA
DB _23032011\$queues\insertevents. The data has been lost.
This error may be caused by a failure of your computer
hardware or network connection. Please try to save this file
elsewhere.
Windows - Corrupt File
The file or directory \VISTA DB
_23032011\$queues\insertevents is corrupt and unreadable.
Please run the Chkdsk utility.
TAC Vista
TAC Vista
Problem with Operating System (or) Hard Disk Fault (or) Link between $queues with Vista Database.
As there may be several issues that are causing this, there are three options to look at:
OPTION 1:
  1. Restore the OLD TAC Vista Data Base Backup.
  2. Refer to TAC Vista Technical Manual chapter 26 for re-storing database procedure.
OPTION 2:
There might be a linking problem with this folder and Vista.  Here are the steps to check if this is the problem: If the problem still exists, Check for hard disk errors.
  1. Find the $queues - folder in existing database folder ( \DB\$queues)
  2. Copy the files to an other location and delete current folder (Refer to An efficient method for deleting all queued files in the $queues folder)
  3. Recreate it with same folder names and copy back the files into $queues-folder.
  4. If the problem still exists, Check for hard disk errors.
OPTION 3:
Check for hard disk errors, follow the below procedure:
  1. Go to "My Computer", Right click on Hard Disk Drive – typically - C, and Click on Properties.
  2. Go to Option "Tools" and Click on "Check Now" under "Error-Checking"
  • 5305
