Temperature sensor input is not changing.
  • Temperature sensor input is not changing.
  • BillNeville
    BillNeville
‎2018-09-06 11:09 AM
Temperature sensor input point is not updating. Sensor works fine on another input.
i2 controller
The threshold may be incorrectly set. For example, if it is set to 10 instead of 0.1.
Check the threshold and make sure it is set to 0.1.
Tags (2)
  • 11077
  • update
