Tables and Offsets for MicroNet 50 Series, 100 Series, and IACs
  • Tables and Offsets for MicroNet 50 Series, 100 Series, and IACs
  • CraigEl
    CraigEl
‎2018-09-11 01:43 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-30 05:25 PM
Users require a comprehensive list of tables and offsets for MicroNet 50 series, 100 series, and IAC controllers to support configuration and troubleshooting.
Satchwell MicroNet
  • Satchwell VisiSat
  • Satchwell VisiView
  • Satchwell MicroNet View
To ensure accurate setup and maintenance, it's necessary to define and reference the correct tables and offsets for these controller ranges.
⚠️ Important Notices
  • The MicroNet 50 series controllers (MN350, MN450, MN550, MN650 LCD and Touchscreen) have been withdrawn from sale.
  • The IAC 420, IAC 600, and Touchscreen models have also been discontinued.
  • No direct replacements are currently offered.
For more details, refer to:
  • PA-00495 - Notice of Withdrawal - Satchwell Sigma (PDF)
  • PA-00528 - End of Commercialization - Satchwell Sigma (PDF)
You can download the relevant tables and offsets using the links below:
  • 📥 MicroNet Controllers – Tables and Offsets
  • 📥 IAC Controllers – Tables and Offsets
Note: These documents include object names and configuration references for supported devices.
Tags (2)
  • 11728
  • CraigEllis25
