TSI Pressura RPM20 Hospital Room Pressure Monitors generate Modbus read errors
  • TSI Pressura RPM20 Hospital Room Pressure Monitors generate Modbus read errors
  • CraigEl
    CraigEl
‎2018-09-11 12:57 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-11 02:58 AM
Although data is read correctly from the TSI Pressura RPM20 Hospital Room Pressure Monitor when integrated to a SmartStruxure Solution Automation Server, Modbus read errors and framing errors are seen.
  • SmartStruxure Solution Automation Server
  • SmartStruxure Solution Automation Server Premium
  • Modbus RTU
The instruction manual from the manufacturer incorrectly lists  the Modbus communication parameters for the RPM20 as 9600 baud, 8 data bits, 2 stop bits and no parity.
Investigation of the data from the device shows that the Modbus communications parameters are:
  • 9600 baud
  • 8 data bits
  • 1 stop bit
  • No parity
Ensure that these parameters are set in the Automation Server Modbus Master Network configuration.
  • 18423
