TS-8XXX and TS-9XXX 1,000 Ohm Balco sensor, Celsius temperature resistance table.
  • TS-8XXX and TS-9XXX 1,000 Ohm Balco sensor, Celsius temperature resistance table.
  • CraigEl
    CraigEl
‎2018-09-06 02:31 PM
Last Updated: Administrator CraigEl Administrator ‎2019-06-03 06:53 PM
  • TS-8XXX
  • TS-9XXX
  • 1,000 Ohm Balco sensor
Unknown Cause
Temp (°C) Ohms
-40 779.0
-39 782.3
-38 785.6
-37 788.9
-36 792.3
-35 795.6
-34 799.0
-33 802.3
-32 805.7
-31 809.1
-30 812.5
-29 815.9
-28 819.3
-27 822.7
-26 826.2
-25 829.6
-24 833.1
-23 836.5
-22 840.0
-21 843.5
-20 847.0
-19 850.5
-18 854.1
-17 857.6
-16 861.1
-15 864.7
-14 868.3
-13 871.8
-12 875.4
-11 879.0
-10 882.6
-9 886.2
-8 889.9
-7 893.5
-6 897.1
-5 900.8
-4 904.5
-3 908.1
-2 911.8
-1 915.5
0 919.2
1 923.0
2 926.7
3 930.4
4 934.2
5 937.9
6 941.7
7 945.5
8 949.3
9 953.1
10 956.9
11 960.7
12 964.6
13 968.4
14 972.3
15 976.1
16 980.0
17 983.9
18 987.8
19 991.7
20 995.6
21 999.6
22 1003.5
23 1007.5
24 1011.4
25 1015.4
26 1019.4
27 1023.4
28 1027.4
29 1031.4
30 1035.4
31 1039.4
32 1043.5
33 1047.5
34 1051.6
35 1055.7
36 1059.8
37 1063.8
38 1068.0
39 1072.1
40 1076.2
41 1080.3
42 1084.5
43 1088.6
44 1092.8
45 1097.0
46 1101.2
47 1105.4
48 1109.6
49 1113.8
50 1118.0
51 1122.3
52 1126.5
53 1130.8
54 1135.1
55 1139.4
56 1143.7
57 1148.0
58 1152.3
59 1156.6
60 1160.9
61 1165.3
62 1169.6
63 1174.0
64 1178.4
65 1182.8
66 1187.2
67 1191.6
68 1196.0
69 1200.4
70 1204.9
71 1209.3
72 1213.8
73 1218.3
74 1222.7
75 1227.2
76 1231.7
77 1236.2
78 1240.8
79 1245.3
80 1249.8
81 1254.4
82 1259.0
83 1263.5
84 1268.1
85 1272.7
86 1277.3
87 1282.0
88 1286.6
89 1291.2
90 1295.9
91 1300.5
92 1305.2
93 1309.9
94 1314.6
95 1319.3
96 1324.0
97 1328.7
98 1333.4
99 1338.2
100 1342.9
101 1347.7
102 1352.5
103 1357.3
104 1362.1
105 1366.9
106 1371.7
107 1376.5
108 1381.3
109 1386.2
110 1391.0
111 1395.9
112 1400.8
113 1405.7
114 1410.6
115 1415.5
116 1420.4
117 1425.3
118 1430.3
119 1435.2
120 1440.2
121 1445.2
122 1450.1
  • Field Devices
Tags (2)
  • 3769
  • CraigEllis19
