TAC Xenta OP Access Codes
  • TAC Xenta OP Access Codes
  • RandyDavis
    RandyDavis
  • MikaelKrantz
    MikaelKrantz
‎2018-09-06 01:38 PM
Last Updated: Guinan RandyDavis Guinan ‎2022-06-01 11:59 AM
Xenta OP menu items: Status, Sub menu, Week chart, Holiday chart, Alarm, Access Code, Edit Access Code, Date and Time, Daylight Saving have defined Access Levels:
  • Low Level
  • Medium Level
  • High Level
Accessing the medium or high-level menu items requires a password. What is the default password and how can they be changed? What if the passwords have been lost?
TAC Vista
  • Menta
  • Xenta Controllers
  • Xenta OP
  1. The default password for accessing medium level menu items is: 1111
  2. The default password for accessing high-level menu items is: 2222
  3. These can be changed via the Xenta OP only provided the "Edit Access Code" menu item is present in the OP Tree.
  4. Downloading the controller may reset the access level passwords back to the default.
Tags (2)
  • 5535
  • MikaelKrantz22
100% helpful (2/2)
