TAC Vista graphic editor is hanging.
  • TAC Vista graphic editor is hanging.
  • Jonas_Brissman
    Jonas_Brissman
‎2018-09-06 10:37 AM
If renaming a snippet in the graphic editor it will hang.
TAC Vista graphic editor 1.1.6
The problem is that a space is used in the end of the name, that will cause the graphic editor to hang
Don't use space in the end of a snippet name or use an editor with version 1.1.7 or higher. This problem is corrected in version 1.1.7.
  • 12652
