TAC 200 OTP Controller replacement battery
  • TAC 200 OTP Controller replacement battery
  • CraigEl
    CraigEl
  • Chris_Asbury
    Chris_Asbury
  • sesa139513
    sesa139513
‎2018-09-11 07:02 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 05:43 PM
TAC 200 OTP Controller replacement battery information
Field Devices, TAC Vista
Site with TAC 200 OTP Controller
On-board battery is in need of replacement, Part number - 200-1005-000.
  • Here is additional information:
  • TAC 200 OTP compensator and optimiser
  • TAC 200 OTP is a compensator and an optimiser. It controls the heating via a
    boiler output and a mixing valve or via two stages of gas boilers.
  • TAC 200 OTP can be operated with or without a room sensor.
  • The controller has an easy-to-use operator's panel and needs virtually no maintenance.
  • TAC 200 OTP is also described in the following documents, all available in English:
  • Data sheet TAC 200 OTP C-10-31
    The data sheet contains a comprehensive specification of the controller and should be read together with the handbook (part number 0-003-1148).
  • A brief instruction
    A small leaflet normally placed in a slot in the operator's panel (part number 0FL-3564).
  • User's manual TAC 200 OTP
    The user's manual (part number 0FL-3563) is a description for installation and start-up, packed together with the unit. The contents are a condensed version of chapter 2 in this manual and a mounting instruction.
  • Manuals are available in TAC 200 OTP User Guide, TAC 239W DHW User Guide.
Replacement battery is 342200360 CAP, .22 F 5.5V RM5
Labels (2)
  • Field Devices
  • 15763
