System Plug-In has deleted the TAC Network
  • System Plug-In has deleted the TAC Network
‎2018-09-07 10:10 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:05 AM
The System Plug-In had a failure and when reopened the TAC Network was missing.
Microsoft Window XP SP3
TAC Vista 5.1.4
The failure on the System Plug-In has caused the TAC network to be removed.
To reinstate the removed TAC Network in the System Plug-In follow these steps.
  1. Ensure that the Vista Database has not been updated with the blank System Plug-in TAC Network view. If this has been done restore a recent backup of the Vista DB. See TAC Vista Technical Manual for restore process.
  2. From the heading bar on the System Plug-in select TAC Network
  3. Then select Import TAC Network
  4. Enter the database user name and password where prompted.
  5. Select Yes to the "Overwrite current edited TAC Network" prompt.
  6. Select your current Lonworks network.
  7. The current Vista database will then be imported into the system Plug-In.
  • 5017
