Suprema Biometric readers offline in Security Expert client
  • Suprema Biometric readers offline in Security Expert client
  • AdamSteele
    AdamSteele
  • CraigEl
    CraigEl
Guinan AdamSteele Guinan
‎2024-02-04 03:22 PM
  • After configuration, Suprema readers are showing as offline in the Security Expert client.
  • There are Security Expert Download Service events logged in the windows application event log.
    • Cannot load DLL - LoadLibrary() Failed.
Cannot load DLL event mesageCannot load DLL event mesage
EcoStruxure Security Expert
  • Security Expert
  • Suprema biometric readers
Required DLL SecurityExpertSV2.ThirdParty.dll is missing from the installation folder. Some versions of Security Expert installer will not install this required DLL and the file need to be manually added.
Check the Security Expert install folder, typically C:\Program Files (x86)\Schneider Electric\Security Expert, to confirm if the file SecurityExpertSV2.ThirdParty.dll is present.
SecurityExpertSV2.ThirdParty.dllSecurityExpertSV2.ThirdParty.dll
If the file is not in the installation folder then it can be sourced from the integration guide ZIP package. AN 264 Security Expert - Suprema Biometric - Integration Guide contains the three DLL's required for the integration. Install the file by copying it into the installation folder, then restart all of the Security Expert services or restart the Security Expert server.
  • EcoStruxure Security Expert
  • AdamSteele24
