Summary view for Forced Value on I/O
  • Summary view for Forced Value on I/O
  • Mahmoud_Sayed
    Mahmoud_Sayed
  • sesa139513
    sesa139513
‎2018-09-06 12:06 PM
Last Updated: Kirk Mahmoud_Sayed Kirk ‎2023-08-21 04:38 AM
  • Building Operation Enterprise Central
  • Building Operation Automation Server
  • Building Operation Automation Server Premium
  • Building Operation Automation Server Bundled
Automation Server or any of connected devices can potentially have many points or values. Need to discover which ones are in Forced state.
Examples: A Digital Output with default value:
Digital Output with Forced value and ON:
Digital Output with Forced value and OFF:
You can search for forced values using the search function in WorkStation. Enabling In device option will enable finding forced values on devices hosted under EBO, as SpaceLogic and EasyLogic devices, MP and RP controllers, IP-IO modules and RP-IO modules.
For more information, see Searching for Forced Values .
You can also view the search in WebStation:
In EBO 2023 or later, You can search for forced values in WebStation using Diagnostics.
For more information, see Displaying a List of Forced Values in WebStation .
Tags (8)
  • 11229
  • 19147
  • alm
  • along
  • defect
  • MahmoudSayed23
  • requests
  • way
