Sub-Lan Interface (SLI) Not Available.
  • Sub-Lan Interface (SLI) Not Available.
  • sesa139513
    sesa139513
  • Roger_Bently
    Roger_Bently
‎2018-09-06 03:06 PM
I/NET site with SLI
Controller is not available to translate a big card number when it has been read at a card reader. .
If you are using Access control and wondered what "SLI Not available" means or how it should be used when setting up Messages on the Door Point, the following description should clear up any misconceptions about it.
"SLI Not Available" means that the controller is not available to translate a big card number when it has been read at a card reader.
This can be set up as a Transaction or an Alarm.
A Transaction will be displayed in the Transaction Window whenever this occurs.
An Alarm will be generated if this is selected but it has to match the settings that are selected for the various Alarm type and distribution masks.
  • TAC INET
  • 1980
