StruxureWare Buildings Operation - How can a PVR module in the Function Block Program be bound directly to a "Value" object?
  • StruxureWare Buildings Operation - How can a PVR module in the Function Block Program be bound directly to a "Value" object?
  • sesa125819
    sesa125819
‎2018-09-06 12:27 PM
Binding a PVR module in the Function Block Program directly to a "Value" object?
FBP
PVR module
The PVR module is not available to bind in the binding window.
To enable the PVR module to be bound, it must first be made "Public", this is selected when editing the module.
Having saved the Function Block Program, the PVR module can now be bound in the normal way.
  • 7872
