StruxureWare Building Operation AS status data
  • StruxureWare Building Operation AS status data
  • sesa139513
    sesa139513
  • RobertAndriolo
    RobertAndriolo
‎2018-09-06 03:31 PM
Automation Server
AS Information program such as CpuUsage, MemUsage, ProductID, Partnumber, Serial, SWversion, and much more.
The attached file can be imported into a AS (with any or the releases 1.1.x  through the current release 1.5.x). It will create two graphics that supply a wealth of operational information. Screenshots are shown below:
After import into your AS, look for System View folder. Open to view the two ProgramInfo and SystemInfo tabs.
Please note that you can also see the CPU% and memory usage of the AS by using Building Operation Workstation, highlight the AS, go to the Properties tab and in Basic, the stats are listed.
Tags (10)
  • 100%
  • 7573
  • bandwidth
  • overload
  • overloaded
  • percent
  • process
  • processor
  • statistics
  • task
