StruxureWare Building Operation 1.3.0 SP1 Installation
  • StruxureWare Building Operation 1.3.0 SP1 Installation
  • RobertAndriolo
    RobertAndriolo
  • Derrick_Ratliff
    Derrick_Ratliff
‎2018-09-11 03:43 AM
Problems after installation of Service Pack 1
SmartStruxure 1.3.0 SP1 Build 10100
The Service Pack must be installed on top of an existing 1.3.0.938 build of Building Operation
To use the Service Pack:
  1. Install or verify installation of 1.3.0.938
  2. Run the installers (see link below if you require additional detail)
  3. Be sure to select the "Upgrade" and not the "Uninstall" option
The Online help (link below) provides a step by step workflow for this Service Pack, so you require additional detail.
http://help.sbo.schneider-electric.com/Topics/show.castle?id=9389&locale=en-US&productversion=1.3&a=...
  • 12906
