Starting CyberStation and get the error "Application failed to initialize properly".
  • Starting CyberStation and get the error "Application failed to initialize properly".
  • BillNeville
    BillNeville
‎2018-09-06 10:01 AM
CyberStation error on startup
CyberStation v1.91, Windows XP Pro SP3
Windows user permissions
Random DLL files didn't have the proper permissions.
The steps to fix it:
1)       Log in as the user that can't start CyberStation.
2)       Launch ProcessMonitor.
3)       Launch CyberStation (it should error out)
4)       Click the filter button in ProcessMonitor then filter for Process: "Continuum.exe" or Result: "Access Denied"
5)       Find one that failed.  Log in as the admin user and change the permissions.
6)       Repeat for each failed file.
  • 14502
