Spare Addresses for use as internal points on an SCU 1284 dual address
  • Spare Addresses for use as internal points on an SCU 1284 dual address
  • RobertAndriolo
    RobertAndriolo
  • Derrick_Ratliff
    Derrick_Ratliff
‎2018-09-06 12:53 PM
Last Updated: Picard RobertAndriolo Picard ‎2023-12-21 10:50 PM
TAC INET
  • I/NET Access Control
  • SCU1284 dual address mode
What are the ramifications of using the spare point addresses for internal points in an SCU 1284
Note! It's generally not recommended to use the available address on a subLAN. Addresses marked as "Internal" in the MCU configuration are reserved for internal software points. However, it's crucial to consider that doing so may limit the potential expansion of the subLAN to utilize these addresses in the future.
When a SCU1284 is set to dual channel, it only uses 12 inputs, 8 outputs, and 4 reader points.  Here is a list of all software points and their uses:
XX00 DI - XX03 DI Hardware Inputs used by doors
XX04 DI - XX07 DI Spare Hardware Inputs
XX08 DI & XX09 DI SCU tamper and power monitoring points
XX00 DO - XX03 DO Hardware Outputs
XX04 DO - XX07 DO Spare software only points
XX08 DO & XX09 DO Reader Points
YY00 DI - YY03 DI Hardware Inputs used by doors
YY04 DI - YY09 DI Spare software only points
YY00 DO - YY03 DO Hardware Outputs
YY04 DO - YY07 DO Spare software only points
YY08 DO & YY09 DO Reader Points
See the following documentation: TCON312-0910.book (schneider-electric.com)
  • TAC INET
Tags (2)
  • 6933
  • RobertAndriolo23
