SpaceLogic BACnet/IP devices firmware compatibility with EBO and Tridium Niagara N4
Select a Country
  • SpaceLogic BACnet/IP devices firmware compatibility with EBO and Tridium Niagara N4
  • RandyDavis
    RandyDavis
  • PeterEdvik
    PeterEdvik
  • Mahmoud_Sayed
    Mahmoud_Sayed
Mahmoud_Sayed Champion
‎2021-09-28 11:35 AM
Last Updated: RandyDavis Champion ‎2025-09-10 06:33 AM
What is the compatible SpaceLogic BACnet/IP device firmware version for my EBO or Tridium Niagara N4 installation?
EcoStruxure Building Operation, TAC IA Series
  • Tridium Niagara N4.10 and later versions Jace 8000/9000
  • Tridium Niagara N4.10 and later versions Enterprise Server
The SpaceLogic (formerly known as SmartX) IP Controllers shipped from the factory may not have the latest firmware installed. It is essential to verify that the controller has the latest firmware build loaded for the EcoStruxure Building Operation version or Tridium Niagara N4 build being used before programming the controller.
The below table contains the supported SpaceLogic BACnet/IP devices firmware for each EBO release.
* CPs are available on: EBO Hotfix List
Note: Versions not mentioned in the table above are out of full support. Refer to earlier versions' release notes for the older versions' compatibility matrix, refer to EBO- Release Notes and Software Support Policy for EcoStruxure™ Building Operation
Note: RP-C is only supported on EBO 3.0 and later
SpaceLogic/EasyLogic versions compatibility
SpaceLogic BACnet/IP devices can be upgraded using WorkStation, as explained in Updating Firmware in BACnet/IP Controllers.
SpaceLogic BACnet/IP devices firmware can also be upgraded using the eCommission SmartX Controller mobile application, you can download firmware to either a single BACnet/IP controller or multiple controllers, even if not hosted. This is only supported over an IP connection, as explained in Using the eCommission SmartX Controller Mobile Application to Download Firmware to BACnet/IP Control...
Tridium Niagara N4 Compatibility
Note: Previous to Version 1.0, SpaceLogic BACnet/IP devices firmware is only approved at v3.02.03 for Jace 8000 and Niagara Enterprise Server using N4.10 and newer platforms.
Starting in Version 2.0 (Build 77) firmware v4.00.04.02002 CP1 is approved for use.  Make sure and reference the controller type in the table above as well. Release Notes
Starting with Version 3.1 (Build 85), firmware 6.00.03.03007 CP2 and 7.x RC can be employed. The EasyLogic controllers are supported by the Niagara modules with these releases.  N4.10, 4.13, 4.14 and 4.15 are the only versions with these modules. Product Announcement
Labels (2)
  • Automated Engineering Tool
Tags (5)
  • MahmoudSayed21
  • MahmoudSayed22
  • MahmoudSayed23
  • MahmoudSayed24
  • MahmoudSayed25
100% helpful (1/1)
