Software permission on point level
  • Software permission on point level
  • RandyDavis
    RandyDavis
  • Jonas_Brissman
    Jonas_Brissman
Janeway Jonas_Brissman Janeway
‎2021-02-01 01:11 PM
on ‎2021-02-01 01:11 PM
Is it possible to set software permissions for a Public Value in a Menta or Function Block program in EcoStruxure Building Operation (EBO)?
Building Operation Workstation
Public values in Function Block Programs (FBP) or Menta programs are not seen as objects but as attributes of the FBP or Menta object.
It is not possible to set software permission on point level for a Menta program or Function Block Program, only on the Module level.
One workaround is to create a Search or Watch View and add the signals the user should be able to change or add the points to a graphic.
Set permissions to the Search, Watch window, or graphic.
Tags (4)
  • function block
  • JonasBrissman20
  • public
  • xenta
100% helpful (1/1)
