SmartStruxure 1.3 user accounts - Can a user have access to change a value on a Graphic, without access to its other functions?
  • SmartStruxure 1.3 user accounts - Can a user have access to change a value on a Graphic, without access to its other function...
  • sesa139513
    sesa139513
  • sesa125819
    sesa125819
‎2018-09-06 10:47 AM
Access which allows a value to be changed, also allows other changes to be made.
Users
User accounts
A user account is created to have read only access, but this user must also have access to view Graphics, and on these graphics, be able to change values. How can this be achieved without allowing the user access to delete or edit these objects?
At StruxureWare Building Operation release 1.3 there are no available options that will achieve this configuration, the most appropriate configuration is to create a Workspace for the user, in which they will see only the Graphics, the user would have Read/Write access to the values they are allowed to change.
  • 12100
