SigmaX - Error message when starting SigmaX
  • SigmaX - Error message when starting SigmaX
  • DavidChild
    DavidChild
  • sesa125819
    sesa125819
‎2018-09-06 01:44 PM
Last Updated: Sisko DavidChild Sisko ‎2020-10-06 07:13 AM
Error message when starting SigmaX, says "Failed to Create Object", once accepted SigmaX works correctly.
Satchwell Sigma
  • Sigma
  • SigmaX
  • Tools
  • Utilities
Sigma Graphics has not correctly registered in the system registry.
This issue is rectified as detailed below.
1 - Close SigmaX if running.
2 - Start the Sigma server and client.
3 - Open the Sigma graphics editor, and either open an existing graphic, or start a new one.
4 - Modify the graphic and then save the changes.
5 - Shutdown the Sigma client and server, Start SigmaX and confirm its operation.
  • Satchwell BAS & Sigma
Tags (2)
  • 5325
  • DavidChild20
