Sigma and SigmaX - Network connections
Select a Country
  • Sigma and SigmaX - Network connections
  • CraigEl
    CraigEl
  • RogerHa
    RogerHa
‎2018-09-06 12:14 PM
Last Updated: CraigEl Champion ‎2025-10-01 08:01 PM
When using SigmaX to unlock Sigma, the PC ID of the server machine may change, preventing clients from connecting.
Satchwell Sigma
  • Sigma - All Versions
  • SigmaX
Modern PCs often have multiple network ports. When SigmaX is used to unlock Sigma, the PC ID may change if a different network port is used for the main connection. This typically occurs when switching between wired and wireless connections.
To prevent the PC ID from changing:
  1. Ensure the PC is connected via a wired Local Area Connection (LAN) when installing SigmaX. This connection will be used to generate the PC ID.
  2. Set the wired LAN as the primary network connection:
    • Open:
      Control Panel > Network Connections > Advanced > Advanced Settings
    • In the Adapters and Bindings tab, use the up/down arrows to move the Local Area Connection to the top of the list.
  3. Once set, you can safely use a wireless connection without affecting the PC ID.
  • Satchwell BAS & Sigma
Tags (2)
  • 8134
  • CraigEllis25
