Sigma - Using an Analogue Input card to display Digital Inputs.
  • Sigma - Using an Analogue Input card to display Digital Inputs.
  • sesa125819
    sesa125819
‎2018-09-06 02:05 PM
Using an Analogue Input card to display Digital Inputs when no Digital Input channels are available.
Sigma Analogue Input cards.
There are no Digital Input channels available.
An Analogue Input card cannot be used directly as a Digital Input card. A work around for this is to configure an Analogue Input to act as a Digital Input.
  1. Programme an Analogue Input object in Sigma.
  2. In Sigma System Manager create a lookup table, using an appropriate free number.
    Input Output
    0 1
    15 0
    20 0
  3. Add the above Lookup table to the Analogue Input object.
  4. In Sigma System Manager create a Short Text such as On/Off =%2.f
  5. Add the new short text number to the Analogue Input object.
  6. Across the Analogue Input channel fit a 1000 ohm resistor, this will be in parallel with the Digital Input connections.
When the Digital Input changes state, Sigma will display either 1 or 0.
  • Satchwell BAS & Sigma
  • 4692
