This article explains how a Sigma UNC controller manages log data when communication with the server is interrupted.
Satchwell BAS & SigmaEnvironment
- Satchwell Sigma - All versions
- UNC Controllers (V53 and ARM7 Series)
During normal operation, Sigma controllers log data and periodically upload it to the logging database. These uploads are managed by the UNC controller. If communication with the server fails, the controller temporarily stores the data in RAM until the connection is restored.
When communication to the server is lost, the UNC controller follows a structured process to manage log data:
- Alarm Buffer Initialization
- After all files are downloaded, the Alarm Buffer is created.
- It queues alarms and logs destined for the server.
- Capacity: Up to 500 entries.
- Logging Buffer Allocation
- Memory is allocated to the Logging Buffer, which stores partially completed log data.
- V53 Series Controllers (532, 496/596, IC1):
Allocated 75% of remaining memory. - ARM7 Series Controllers (632, 696/796, IC3):
Allocated 512 kB.
- Logging Track Structure
- The Logging Buffer uses 138-byte Tracks, with one Track per logged object.
- Log records are added to the Track as events occur.
- Once full, the Track is transferred to the Alarm Buffer.
- Records per Track by Object Type
Log Type Object Type Records per Track Timed Analogue 25 Timed Digital 100 Event Analogue 14 Event Digital 32 Alarm/Report (Log) Any 28 -
Manual Log Retrieval
Partially full Tracks can be manually transferred to the Alarm Buffer via:
Diagnostics > Options > Retrieve Logs
Autodial Connection Behavior
If an Autodial connection is configured, a call is initiated when:
- Any non-opportunistic alarm or log is placed in the Alarm Buffer.
