Sigma - Two IC3-Modbus controllers interrogating a Modbus TCP slave device.
  • Sigma - Two IC3-Modbus controllers interrogating a Modbus TCP slave device.
  • DavidChild
    DavidChild
  • sesa125819
    sesa125819
‎2018-09-10 12:20 AM
A backup device is required for an IC3-Modbus.
Satchwell Sigma
  • Sigma
  • IC3-Modbus
Is it possible to use two IC3-Modbus controllers to interrogate one Modbus slave device?
This configuration is acceptable where TCP is used, it cannot be used for RS485 RTU communications.
Each Modbus device on a TCP network must have a unique ID but everything else (such as register address, type, Gateway IP address) may be identical.
In a RS485 RTU modbus environment, there can only be one master device.
IC3-Modbus datasheet
  • Satchwell BAS & Sigma
Tags (2)
  • 5667
  • DavidChild20
