Sigma Server crashes soon after startup. Anti-Virus is also on the same machine.
  • Sigma Server crashes soon after startup. Anti-Virus is also on the same machine.
  • CraigEl
    CraigEl
  • DavidChild
    DavidChild
‎2018-09-06 11:00 AM
Last Updated: Administrator CraigEl Administrator ‎2025-10-21 09:58 PM
Sigma Server fails shortly after startup. This issue occurs on a machine where anti-virus software is also installed.
Symptoms
  • Sigma services fail to start.
  • Windows Event Viewer logs show Sigma service failure.
  • Anti-virus logs may show Sigma files as quarantined or deleted.
Satchwell BAS & Sigma
Satchwell Sigma
The Sigma Server previously operated normally but now crashes consistently upon startup. This is typically due to a recent update to the anti-virus definitions, which may incorrectly flag a Sigma file as suspicious.
  1. Check Anti-Virus Logs:
    • Review logs to identify if any Sigma files have been quarantined or deleted.
    • Look specifically in:
      • Quarantine directory
      • Deletion logs
  2. Restore or Reinstall Sigma Files:
    • If files are quarantined, restore them.
    • If files are deleted, reinstall Sigma to recover missing components.
  3. Adjust Anti-Virus Settings:
    • Exclude the following directories from real-time scanning:
      • C:\Sigma\Data
      • C:\Sigma\Bin
    • Note: Coordinate with site IT for approval and implementation of exclusions.
  • Satchwell BAS & Sigma
Tags (2)
  • 11417
  • CraigEllis25
