Sigma - Program to calculate the Sunrise time / Sunset time
  • Sigma - Program to calculate the Sunrise time / Sunset time
  • CraigEl
    CraigEl
‎2018-09-10 10:43 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-07 11:38 PM
Customer requires a program to calculate sunrise and sunset times for Sheffield using Sigma programmable objects.
Satchwell BAS & Sigma
There is no built-in function in Sigma to calculate sunrise/sunset times. A custom program is needed to determine these values based on date and location.
To review sunrise/sunset times for a specific location:
  1. Visit the Sunrise/Sunset Almanac Tool.
  2. Enter the desired location and click GO.
  3. Select Almanac > Sunrise/Sunset.
  4. Choose the required month to view the data.
Alternatively, use the following Sigma programmable objects to calculate these values directly.
Programmable Objects
Object 1 – Day of the Year Calculation
10  XInt = DAY
20  IF MONTH >= 2 THEN XInt = XInt + 31
30  XFlo = FLOAT(YEAR)
40  XFlo = XFlo / 4.00000
50  XFlo = FRAC(XFlo)
60  IF XFlo = 0.000000 THEN YInt = 1 ELSE YInt = 0
70  IF YInt = 0 AND MONTH >= 3 THEN XInt = XInt + 28
80  IF YInt = 1 AND MONTH >= 3 THEN XInt = XInt + 29
90  IF MONTH >= 4 THEN XInt = XInt + 31
100 IF MONTH >= 5 THEN XInt = XInt + 30
110 IF MONTH >= 6 THEN XInt = XInt + 31
120 IF MONTH >= 7 THEN XInt = XInt + 30
130 IF MONTH >= 8 THEN XInt = XInt + 31
140 IF MONTH >= 9 THEN XInt = XInt + 31
150 IF MONTH >= 10 THEN XInt = XInt + 30
160 IF MONTH >= 11 THEN XInt = XInt + 31
170 IF MONTH >= 12 THEN XInt = XInt + 30
180 RETURN VIA TEXT
200 VALUE XInt
Object 2 – Sunrise Time Calculation
10  XFlo = POINT 0|1
20  YFlo = FLOAT(YEAR)
30  YFlo = YFlo / 4.00000
40  YFlo = FRAC(YFlo)
50  IF YFlo = 0.000000 THEN YInt = 1 ELSE YInt = 0
60  IF YInt = 1 AND MONTH >= 3 THEN XFlo = XFlo - 1.00000
70  ZFlo = LOOKUP(1001, XFlo)
80  ZFlo = ZFlo / 60.0000
90  YFlo = FRAC(ZFlo)
100 ZFlo = ZFlo - YFlo
110 YFlo = YFlo * 60.0000
120 YFlo = YFlo / 100.000
130 ZFlo = ZFlo + YFlo
140 RETURN VIA TEXT
203 VALUE ZFlo
Object 3 – Sunset Time Calculation
(Same logic as Object 2, using different lookup values)
Object 4 – Sunrise/Sunset Interlock
10  XFlo = POINT 0|2
20  YFlo = FRAC(XFlo)
30  XFlo = XFlo - YFlo
40  YFlo = YFlo * 100.000
50  IF HOUR >= INT(XFlo + 1.00000) THEN GOTO 90
60  IF HOUR = INT(XFlo) THEN GOTO 100
70  XInt = 0
80  RETURN FALSE "Plant Off"
90  XInt = 1
100 IF MINUTE >= INT(YFlo) THEN XInt = 1
110 XFlo = POINT 0|3
120 YFlo = FRAC(XFlo)
130 XFlo = XFlo - YFlo
140 YFlo = YFlo * 100.000
150 IF HOUR >= INT(XFlo) THEN GOTO 170
160 GOTO 180
170 IF HOUR >= INT(XFlo + 1.00000) OR MINUTE >= INT(YFlo) THEN XInt = 0
180 IF XInt = 1 THEN RETURN TRUE "Plant On"
190 RETURN FALSE "Plant Off"
  • Sunrise-Sunset Times.zip – Includes lookup table and object files.
  • Satchwell BAS & Sigma
Tags (2)
  • 8392
  • CraigEllis25
