Sigma: Preventing DeviceCnf.rec Overwrite During Backup Restoration
  • Sigma: Preventing DeviceCnf.rec Overwrite During Backup Restoration
  • CraigEl
    CraigEl
  • sesa119747
    sesa119747
  • Gary
    Gary
‎2018-09-06 02:29 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-21 12:21 AM
When running Sigma 4.05 with a backup from a previous Sigma release, the DeviceCnf.rec file is overwritten with a default or blank version.
Satchwell BAS & Sigma
Sigma 4.05 and later
Sigma 4.05 introduces a new format for the DeviceCnf.rec and GenCnf.rec files. If these files are not in the expected format, Sigma automatically replaces them with default versions during startup or backup restoration.
To prevent data loss and ensure compatibility:
  1. Use the Sigma Upgrade Tool:
    • Navigate to:
      C:\sigma\bin\SigUpgrade.exe
    • This tool upgrades your existing configuration files (DeviceCnf.rec and GenCnf.rec) to the correct format for Sigma 4.05.
  2. Steps to Upgrade:
    • Close Sigma if it's running.
    • Launch SigUpgrade.exe as Administrator.
    • Select the backup files you wish to upgrade.
    • Follow the on-screen instructions to complete the upgrade.
    • Restart Sigma and verify that the configuration files are intact.
  • Satchwell BAS & Sigma
Tags (2)
  • 3838
  • CraigEllis25
