Sigma - Incorrect Image Name Displayed in Download Window
  • Sigma - Incorrect Image Name Displayed in Download Window
  • CraigEl
    CraigEl
  • DavidChild
    DavidChild
‎2018-09-10 04:42 AM
Last Updated: Administrator CraigEl Administrator ‎2025-10-21 11:56 PM
When attempting to download an image file for a controller, the IC-UNIFACT image is incorrectly displayed in the download window instead of the expected IC-SNP image. This occurs on sites where Unifact URC1201/2201 controllers are installed.
Satchwell BAS & Sigma
  • Sigma IC and IC3 controllers
  • Unifact URC1201/2201 controllers
  • IC3-SNP integration
The controller subtype was mistakenly configured as IC-UNIFACT instead of IC-SNP.
As a result, the system displays the image file associated with the configured controller subtype, not the actual hardware installed.
To ensure the correct image file appears in the download window:
  1. Verify and Correct Controller Subtype Configuration
    Navigate to:
    System Setup > Network and Devices > Controllers
    • Select the correct IC subtype: IC-SNP
    • Save the configuration
  2. Download the Correct Image File
    Navigate to:
    System Diagnostics > Options > Download Files
    • The correct image file for IC-SNP will now be displayed
Additional Notes
  • Unifact 1201/2201 controllers use IC-SNP
  • Unifact Pro controllers use IC-UNIFACT
  • Image files are determined by the controller version set in the configuration
  • Satchwell BAS & Sigma
Tags (2)
  • 6554
  • CraigEllis25
