Sigma - IC3-Modbus Documentation.
  • Sigma - IC3-Modbus Documentation.
  • CraigEl
    CraigEl
‎2018-09-10 02:49 AM
Last Updated: Administrator CraigEl Administrator ‎2025-10-30 04:08 AM
Users are unable to locate the documentation for the IC3-Modbus controller used in Sigma systems.
Satchwell BAS & Sigma
Sigma IC3-Modbus
Documentation for the IC3-Modbus controller is not easily accessible or clearly linked within the Sigma support resources.
The following resources are available for download to assist with IC3-Modbus configuration and integration:
  • 📄 IC3-Modbus Gateway Configuration File
    Download Gateway_IC3-Modbus_R4_05.txt
  • 📘 IC3 Configuration Guide
    Download Cguide34_IC3.pdf
  • 📑 IC3-Modbus Data Sheet
    Download DS-13.684_0610_Modbus-Integration-Controller_Data-Sheet.pdf
  • Satchwell BAS & Sigma
Tags (2)
  • 6109
  • CraigEllis25
100% helpful (1/1)
