Sigma IC3-Modbus: Data Type Compatibility (16-bit, 32-bit, 64-bit)
  • Sigma IC3-Modbus: Data Type Compatibility (16-bit, 32-bit, 64-bit)
  • CraigEl
    CraigEl
Gary Schneider Alumni (Retired)
‎2022-09-23 07:50 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-30 12:47 AM
Clarification is needed regarding which Modbus data types are compatible with Sigma IC3-Modbus, particularly concerning 64-bit support.
Satchwell Sigma
Satchwell Sigma IC3 Modbus
Documentation does not explicitly mention support for 64-bit data types, leading to uncertainty.
  • ✅ 16-bit Registers:
    Fully supported across all Sigma versions.
  • ✅ 32-bit Registers:
    Supported from Sigma Release 4_05-SEB (Build 3_43_18) onwards.
    Refer to Sigma IC-Modbus - Reading 32 Bit Integer values from two 16 Bit registers for engineering guidance.
  • ❌ 64-bit Registers:
    Not supported with Sigma IC3-Modbus.
  • Satchwell BAS & Sigma
Tags (2)
  • CraigEllis25
  • GaryMontague22
