Sigma IC-Modbus - Reading a 16 bit signed integer value.
  • Sigma IC-Modbus - Reading a 16 bit signed integer value.
  • DavidChild
    DavidChild
  • sesa125819
    sesa125819
‎2018-09-06 11:08 AM
How can a 16 bit signed integer value be displayed correctly?
Modbus
IC
IC3
16 bit
Signed
A Modbus value is displayed as 65???.
With a 16 bit signed integer value, the range used is +/- 32767, and seeing a value of 65??? indicates a negative value.
The easiest way to read this value is to use a lookup table.
The table should be added as follows.
0          =      0
32767 =      32767
32768 =    - 32767
65535 =    - 0
  • Satchwell BAS & Sigma
  • 11123
