Sigma - Globals do not work when an IP Address structure of 192.168.xxx.xxx Mask 255.255.0.0 is used.
  • Sigma - Globals do not work when an IP Address structure of 192.168.xxx.xxx Mask 255.255.0.0 is used.
  • sesa125819
    sesa125819
‎2018-09-06 12:39 PM
Sigma globals do not work.
Sigma
Globals
Mask 255.255.0.0
Classful
Classless
The site is using a class C address, with a class B subnet mask.
The following is an explanation of why the Sigma globals in this configuration do not work.
An IP Address is divided in to two sections: Net ID and Host ID. The Host ID is further divided in to two Sections: Subnet ID and Host ID.
  • The Subnet Mask determines the Subnet ID bits and Host ID bits.
  • Number of Mask bits should be greater than that of Net ID bits.
For example a Sigma address is 192.168.0.1 with 24 bit mask 255.255.255.0
  • Number of subnet ID bits is zero and Host ID bits is 8;
  • Broadcast address is 192.168.0.255
 With 28 bit mask 255.255.255.240
  • Number of subnet ID bits is 4 and Host ID bits is 4;
  • Broadcast address is 192.168.0.15
 For Class C:
  • Address range is: 192.0.0.0 to 223.255.255.255 inclusive
  • Net ID is 24 bits; Host id is 8 bits; Minimum Mask size is 24 bits;
 For Class B:
  • Address range is: 128.0.0.0 to 191.255.255.255 inclusive
  • Net ID is 16 bits; Host id is 16 bits; Minimum Mask size is 16 bits;
In the site set up, 192.168.xxx.xxx is a Class C address; this can have at least 24 bit mask; 16 bit mask is invalid;
Using an Address 190.168.xxx.xxx works correctly because it is a Class B address and supports 16 bit masking; hence works properly.
For globals to work correctly, either use >= 24 bit mask for the subnet 192.168.xxx.xxx, or move to class B subnet 190.168.xxx.xxx.
  • Satchwell BAS & Sigma
  • 7354
