Sigma - Creating a programmable object to mimic another object value.
  • Sigma - Creating a programmable object to mimic another object value.
  • sesa125819
    sesa125819
‎2018-09-06 01:10 PM
The new programmable object should read an existing object (1) and a time schedule (2). When the time schedule switches off the value from object 1 will be held and outputted. This output will be maintained until the next time schedule off period, when it will be reviewed again.
Sigma
Programmable object
Prog Point
programming
Assistance required to create a programmable object.
The object below will fulfill the requirements.
Use appropriate controller and object numbers.
Object 1 = Existing programme to be monitored
Object 2 = Time Schedule.
10 IF P (2) ON THEN XINT = 1 ELSE XINT = 0
20 IF XINT DOWN THEN GOTO 40
30 GOTO 50
40 IF P (1) ON THEN YINT = 1 ELSE YINT = 0
50 IF YINT = 1 THEN RETURN TRUE "HW"
60 RETURN FALSE "CW"
  • Satchwell BAS & Sigma
  • 6415
