Sigma - Communications with the controllers is very slow.
  • Sigma - Communications with the controllers is very slow.
  • sesa125819
    sesa125819
‎2018-09-06 12:20 PM
Slow communications
Displaying objects seem to lock up
Globals
V53 hardware
Communications with the controllers is very slow. Objects will display correctly once, but if the display is carried out several times, or if an object is overridden, the server appears to lockup.
The issue was caused by two Sigma objects being globally transmitted at the rate of 12 per second. The two objects were Programmable and the programme had been incorrectly written as follows;
10 IF POINT 0|108 = 0.000000 THEN RETURN "Ch1  Off"
20 IF POINT 0|108 = 1.00000 THEN RETURN "Ch1 Start"
30 IF POINT 0|108 = 2.00000 THEN RETURN "Ch1 Running"
40 IF POINT 0|108 = 3.00000 THEN RETURN "Ch1 Shutdown"
50 IF POINT 0|108 = 4.00000 THEN RETURN "Ch1 Service"
The above object is incorrect because it does not specify True or False.
Because globals are transmitted on "change of state" the global was being transmitted with every scan of the object file.
It is recommended that the object is changed as follows.
10 IF POINT 0|108 = 0.000000 THEN RETURN FALSE "Ch1  Off"
20 IF POINT 0|108 = 1.00000 THEN RETURN TRUE "Ch1 Start"
30 IF POINT 0|108 = 2.00000 THEN RETURN TRUE "Ch1 Running"
40 IF POINT 0|108 = 3.00000 THEN RETURN TRUE "Ch1 Shutdown"
50 IF POINT 0|108 = 4.00000 THEN RETURN TRUE "Ch1 Service"
  • Satchwell BAS & Sigma
  • 7969
