Shutting Down I/O Server while running as a Client
  • Shutting Down I/O Server while running as a Client
  • Roger_Bently
    Roger_Bently
‎2018-09-06 02:53 PM
  • I/NET Seven rev 2.X and above
  • I/O Server
Running I/NET I/O Server as a service and need to shut it down in order to do a backup or to run DBCreate.
  1. Close I/NET, since I/O Server will still be running, it can’t be closed.
  2. Open I/O Configuration Editor, if you right click on I/O Server, the Exit button will be grayed out.
  3. Close I/O Configuration Editor, right click on I/O Server again and this time the Exit button will become available and it can be selected.
  4. Select Exit and I/O Server will now be closed.
  5. To restart I/O Server again, either restart the PC or launch it through Administrative Tools > Services > MSQL Agent
  • TAC INET
  • 2813
