Seven Reports unable to run.
  • Seven Reports unable to run.
  • Roger_Bently
    Roger_Bently
‎2018-09-06 01:29 PM
Error when starting Seven Reports getting an error "Copy of prompt.dll failed Error Code 2".
All versions of I/NET Seven and Windows OS.
Administrative privileges on the PC needed to run Seven Reports.
  1. Log off of I/NET and I/O Server.
  2. Shut the PC down and restart it.
  3. Log back in as an Administrator and run the Seven Report again.
  • TAC INET
  • 5795
