Setting up to Print a Report of Off Normal Points and Disabled Points in an I/NET System
  • Setting up to Print a Report of Off Normal Points and Disabled Points in an I/NET System
  • sesa139513
    sesa139513
  • Roger_Bently
    Roger_Bently
‎2018-09-06 03:11 PM
I/NET site
How does one run a report on Off Normal Points and Disabled Points?
There is a new feature in I/NET now that enables the user to run a report on Off Normal Points and Disabled Points. To set this up, the user needs to follow these simple steps:
  1. Start I/NET, log on and go to Edit, Host Computer, Network Functions.
  2. Select the Link that you need the Points to be printed; this displays all the controllers on this link.
  3. Click on the Nrml and Dsbl buttons, this sets up the controller to display these points.
  4. Select Summary, Off Normal Points, a list of points (if any are Off Normal) will be displayed.
  5. In this Editor there is a Print Button, Click on this, it will ask you for a printer that you normally print to.
  6. Click OK and a report will be generated on your printer.
    The same process should be followed for Disabled Points.
  7. Select Summary, Off Normal Points, a list of points (if any are Disabled) will be displayed.
  8. In this Editor there is a Print Button, Click on this, it will ask you for a printer that you normally print to.
  9. Click OK and a report will be generated on your printer.
  • TAC INET
  • 1774
