Setting up an Automatic Pop-up Duress Alarm (Panic) Button with Sound
Select a Country
  • Setting up an Automatic Pop-up Duress Alarm (Panic) Button with Sound
‎2018-09-10 12:26 AM
Last Updated: ContentModerator Explorer ‎2025-08-11 04:07 AM
Is there is an application that will display the duress (panic) button alarm to the operator, when pushed, along with sound.
TAC I/NET
  • I/NET Seven
  • Automatic Page Display, Event Definitions & Sequences, User Defined Button
Sample application / guide to program duress alarms in I/NET.
I/NET provides various functions that allow it to provide a pop-up duress alarm, one feature is to use one (or many) graphic page(s) which automatically appear (pop-up) on activation of an alarm. Along with this, it is also possible to generate a sound either PC based or, the more preferred option, to an externally wired Buzzer / Siren at the same time.
The attached document shows a few steps as a guide to make a start on your own application using the following features:
  • AMT Audible Alarm
  • Event Definition / Sequences
  • User-Defined Tools and Buttons
If you are not familiar with these items you should refer to the TCON documents mentioned in the attachment.
  • TAC INET
Tags (3)
  • 5756
  • panic buttons
  • RobertAndriolo19
100% helpful (1/1)
