Setting default BACnet priority levels in EcoStruxure Building Operation
  • Setting default BACnet priority levels in EcoStruxure Building Operation
  • Mahmoud_Sayed
    Mahmoud_Sayed
  • LeeCravens
    LeeCravens
  • Carl_Slack
    Carl_Slack
‎2018-09-06 11:09 AM
Last Updated: Kirk Mahmoud_Sayed Kirk ‎2023-03-30 02:52 AM
Setting the default BACnet priority levels for different applications avoids priority conflicts by normalizing which priority gets used for a specific action or within a specific application
  • Building Operation Automation Server
  • Building Operation Automation Server Premium
  • Building Operation Automation Server Bundled
  • Building Operation Edge Server - Standard
Different EcoStruxure applications may act upon BACnet objects utilizing different BACnet priority levels. This may cause confusion and can keep the system from operating as expected.
BACnet objects created with EBO (1.4 and higher) will have a default BACnet Priority of 16 unless specified otherwise. The default BACnet Priority can be changed to the customer's needs.
As a best practice, define the Default priority level prior to configuring the system. In addition, consider maintaining the same default priority level for multiple active systems at your site. For example, configure the same default priority level for the EcoStruxure Building Operation and fire protection system.
In a multi-server system, you can only configure the Default priority level from the Interface Manager of the Enterprise Server. If you set a new priority level, the system propagates the change to the other automation servers in the network. Refer to: Default Priority Level (se.com) and Configuring the Default Priority Level (se.com)
Tags (2)
  • 11041
  • MahmoudSayed23
