Setting MNB-1000 to factory defaults
  • Setting MNB-1000 to factory defaults
  • RandyDavis
    RandyDavis
  • sesa119747
    sesa119747
  • sesa116871
    sesa116871
‎2018-09-06 02:56 PM
Last Updated: Guinan RandyDavis Guinan ‎2024-12-17 09:51 AM
How can the MNB-1000 be set back to factory defaults?
TAC IA Series
I/A Series MNB-1000
Reconfigure the MNB-1000
Do the following:
  1. Set all of the dip switches on the MNB-1000 to the ON position (all ones)  and cycle power.
  2. Wait until the controller completely boots up (solid green status light), then change dip switches from all ones back to the desired address.
  3. Cycle power again.
Note - Setting the MNB-1000 back to factory defaults will delete the installed application.
  • TAC IA Series
Tags (2)
  • 2701
  • RandyDavis24
75% helpful (3/4)
