Server does not exist or access denied error when using Continuum DB Initialization.
  • Server does not exist or access denied error when using Continuum DB Initialization.
  • AbeMeran
    AbeMeran
  • BillNeville
    BillNeville
‎2018-09-06 10:59 AM
All settings appear to have correct values but the DB initialization fails with the error mentioned above.
CyberStation
SQL Server
Multiple instances of SQL server installed in the server machine.
When multiple instances of SQL are installed in the server the instance MUST be specified along with the server name.
Example: In the Server Name field of Database Initialization Server window type:
SERVER_MACHINE_NAME\SQL2008
not just SERVER_MACHINE_NAME
  • 11468
