Sequence zero does not run when power is restored to a Micro Regulator (MR)
  • Sequence zero does not run when power is restored to a Micro Regulator (MR)
  • RobertAndriolo
    RobertAndriolo
‎2018-09-06 03:26 PM
Last Updated: Guinan RobertAndriolo Guinan ‎2023-12-21 10:10 PM
Sequence zero does not run when power is restored to the Micro Regulators (MR).
The MRI is on a UPS in another part of the building and never loses power.
TAC INET
  • MicroRegulator (MR) SubLAN devices
  • MicroRegulator Interface (MRI) Controller LAN Interface
By design, sequences are stored in the MRI. Sub-LAN controllers do not store sequences.
Sequence zero is designed to trigger the power restore event (Sequence 0) in the event of the Interface (MRI) power failure being restored, hence the MR will not trigger this sequence 0 in the MRI.  The action is correct.
  • TAC INET
Tags (2)
  • 1115
  • RobertAndriolo23
