Sensor Characteristics for Satchwell Controller Type Sensors
  • Sensor Characteristics for Satchwell Controller Type Sensors
  • CraigEl
    CraigEl
  • Gary
    Gary
‎2018-09-10 05:05 AM
Last Updated: Administrator CraigEl Administrator ‎2025-10-26 04:14 PM
Technicians require accurate resistance values for Satchwell and Sontay sensors to validate performance and troubleshoot temperature-related issues.
Field Devices, Satchwell BAS & Sigma, Satchwell MicroNet
  • Satchwell BAS & Sigma
  • Satchwell MicroNet
Resistance values vary by sensor type and temperature. Having a reference chart ensures correct diagnostics and sensor replacement.
Below is a reference table showing resistance values for various Satchwell and Sontay sensor types across a range of temperatures.
Sensor Resistance Table
DRT, DOT, DDT, DWT, DST, DOS   DD 1401, DW 1202, DR 2253, DWS 1301   DW 1204, DWS 1202   DO 2202
Sontay SAT 1   Sontay SAT 2   Sontay SAT 3   Sontay SAT 4
°C Ohms   °C Ohms   °C Ohms   °C Ohms
-40 9711   0 2094   20 2708   -40 2317
-35 9604   1 2079   25 2592   -35 2246
-30 9465   2 2063   30 2474   -30 2163
-25 9288   3 2046   35 2346   -25 2067
-20 9067   4 2027   40 2216   -20 1962
-15 8796   5 2010   45 2086   -15 1849
-10 8472   6 1992   50 1950   -10 1733
-5 8093   7 1973   55 1818   -5 1617
0 7661   8 1953   56 1792   0 1504
5 7182   9 1934   57 1766   5 1397
10 6667   10 1911   58 1741   10 1298
15 6126   11 1892   59 1718   15 1208
20 5573   12 1872   60 1694   20 1128
25 5025   13 1851   61 1669   25 1057
30 4492   14 1830   62 1646   30 996
35 3987   15 1809   63 1622   35 942
40 3518   16 1787   64 1600   40 897
45 3089   17 1764   65 1578
50 2702   18 1740   66 1553
55 2358   19 1716   67 1530
60 2056   20 1690   68 1508
65 1792   21 1667   69 1484
70 1563   22 1644   70 1461
75 1364   23 1621   71 1439
80 1193   24 1596   72 1417
85 1047   25 1574   73 1396
90 921   26 1549   74 1375
95 815   27 1524   75 1353
100 722   28 1500   76 1333
105 643   29 1476   77 1312
110 575   30 1452   78 1293
115 517   31 1430   79 1276
120 466   32 1406   80 1258
125 423   33 1383   81 1240
130 386   34 1359   82 1222
135 353   35 1336   83 1205
140 324   36 1312   84 1188
145 300   37 1289   85 1171
150 278   38 1267   86 1154
      39 1243   87 1138
      40 1219   88 1122
      41 1198   89 1107
      42 1176   90 1089
      43 1155   91 1075
      44 1134   92 1061
      45 1113   93 1047
      46 1092   94 1033
      47 1072   95 1020
      48 1052   96 1004
      49 1033   97 991
      50 1013   98 978
            99 964
            100 950
📎 Note: These values are approximate and may vary slightly depending on installation conditions. Always refer to the official datasheet or use calibrated instruments for precise diagnostics.
Click here to download a pdf with this information.
Labels (3)
  • Field Devices
Tags (2)
  • 6803
  • CraigEllis25
