Seeing License Expired message when launching Security Expert
  • Seeing License Expired message when launching Security Expert
  • RobertAndriolo
    RobertAndriolo
  • AdamSteele
    AdamSteele
Guinan AdamSteele Guinan
‎2021-06-21 12:13 AM
When launching Security Expert after restarting the PC, a License Expired message is shown. The license is not able to be found.
Security Expert
  • Security Expert Client
  • Security Expert Licensing
This is a timing issue. The Security Expert services are attempting to start simultaneously as Windows components that they rely on.
Change the Startup Type of the Security Expert services to use Automatic (Delayed Start), so they start after the Windows OS components.
Services - Automatic DelayedServices - Automatic Delayed
It is also possible that the Security Expert Data Service may be the only service that requires being set to a delayed startup to resolve this problem.
  • EcoStruxure Security Expert
  • AdamSteele21
100% helpful (1/1)
