Security Expert compatibility with SQL Clustering
  • Security Expert compatibility with SQL Clustering
  • RandyDavis
    RandyDavis
  • Sampath_Konda
    Sampath_Konda
  • AdamSteele
    AdamSteele
Commander Sampath_Konda Commander
‎2020-02-25 06:18 AM
Last Updated: Guinan AdamSteele Guinan ‎2021-09-30 10:21 PM
Is any version of Security Expert compatible to install in SQL Clustering?
Security Expert
  • Security Expert
  • Microsoft SQL Server
Installation and configuration of Security Expert databases (Security Expert and Security Expert Events) in SQL Clustering
There is not currently a Tested Validated Documented Architecture (TVDA) for Security Expert compatibility with SQL Clustering so it is not officially supported. It is recommended to install and configure in standard SQL Server versions. Click here to refer compatibility matrix for supported environments.
  • EcoStruxure Security Expert
Tags (6)
  • Clustering
  • Microsoft SQL
  • MS SQL
  • SampathKonda20
  • SampathKonda21
  • tvda
0% helpful (0/1)
