Security Expert DIN-Rail Pluggable Terminal Block Replacements for Modules
  • Security Expert DIN-Rail Pluggable Terminal Block Replacements for Modules
  • RandyDavis
    RandyDavis
  • JamesMorgan
    JamesMorgan
Lieutenant JG JamesMorgan Lieutenant JG
‎2022-08-03 10:40 AM
on ‎2022-08-03 10:40 AM
Where can we order pluggable/screw terminal block replacements?
Security Expert
Security Expert Controller
Pluggable/screw terminal blocks are not available for order
SE does not sell pluggable terminal blocks because they are readily available online
Find part number etched on side of the terminal block.
For example:2EDGK5.00-04P14
Full pluggable terminal block catalogue
  • EcoStruxure Security Expert
  • JamesMorgan22
