Script program - Using the Binding Attribute "variable.OFFLINE" does not indicate that an I/O module is offline.
  • Script program - Using the Binding Attribute "variable.OFFLINE" does not indicate that an I/O module is offline.
  • sesa139513
    sesa139513
  • sesa125819
    sesa125819
‎2018-09-11 06:27 AM
The binding variable "variable.OFFLINE" does not reflect an offline state.
Script Program
Binding Attribute
Offline
Release 1.4.1
A program has been written which uses this attribute to confirm that an I/O is online, but the state does not change.
Web-Help - describes the use of the Binding Attributes Forced, Invalid, Offline and Overridden.
These attributes were originally intended to be available, but it was decided that they would not be implemented at this stage of the SmartStruxure development.
This information will now be removed from the documentation, until the Binding Attributes are correctly introduced in a later release.
  • 15796
